NZXT PHANTOM 530 Review
Back at the start of this decade NZXT released the original Phantom. Representing as it did a bit of a change in aesthetic direction it wasn’t without its detractors. The main criticism levelled at it, and as such, subsequent continuations of the breed was that it was insubstantial and “plasticy”, although it has to be said that these comments came predominantly from those who had never actually seen ones in the flesh. Wind the clock on 3 years and following the larger 820 and 630, and of course the smaller 410, we now have the 530, sitting as you might imagine both size and price wise between the 410 and 630.
In trying to make a little more sense as to where the 530 sits in the range, it’s perhaps easier to think of the 530 as a cut down 630 rather than a larger 410. This is in the main due to it offering much the same functionality of the 630 in a smaller enclosure.
For full details of Specification and features best we have a look at the tables
Technical Specification
Size |
Full Tower |
Model Number |
CA-PH530-W1 White |
Drive Bays |
External 5.25″ x 3 |
Cooling System |
Front 2x140mm/ 120mm or 1x200mm |
Water Cooling Support |
Roof: Up to 360mm (120.3) or 280mm (140.2) Max 43mm depth including fans Front: Up to 240mm (120.2) Max 135mm depth including fans Floor: Up to 240mm (120,2) Max depth 75mm not including fans |
Clearances |
CPU 183mm VGA 282mm (With Pivot Fan) |
Dimensions |
235mm x 572mm x 543mm |
Material |
Steel, Plastic |
Motherboard Support |
ITX, Micro-ATX, ATX, EATX (322x272mm) |
Expansion Slots |
8 |
External Electronics |
1 x Audio / Mic |
Product Weight |
10.5 kg |
Warranty |
2 Years |
Features
- Single channel, 30W fan controller with integrated fan hub
- Up to three 200mm fans for maximum airflow
- Discrete SSD mount behind motherboard tray
- 34mm of cable management clearance
- Fully modular, interchangeable hard drive cages
- Signature rear I/O LEDs + Latest USB 3.0 connection
- Large acrylic window
- Extensive liquid cooling support includes Kraken X40/X60 all-in-one solutions and radiators of up to 360mm in size
