OrigenAE X15e HTPC ATX Case
Cooling & Accessories
Cooling, especially in HTPC cases is a double-edged sword. On one hand you need the best cooling possible to prevent any failures due to overheating components, yet on the other hand you don’t want a HTPC in your living room that sounds like a vacuum cleaner!
Unfortunately I was unable to find the exact specifications of these fans, but I must say that they operate very quietly.
The larger remote is exactly the same model included with the X10, and is capable of controlling all aspects of TV/DVD functionality on your HTPC. You will however need to download the drivers from OrigenAE’s website, as no driver disk is included.
To prevent your beige DVD drive from sticking out like a sore thumb OrigenAE have included a brushed aluminium DVD face plate which can be affixed to the front of your drive using the provided sticky pad.
As you’d expect, a large bag of screws along with some cable tidies has also been provided.
