Riotoro CR1080 Review
Good things come in small packages, or so they say. Well, whether they do or don’t, they do at least take up less space, and provided they give the same flexibility and performance, what’s not to like? The Riotoro CR1080 is certainly small, measuring just 359x245x394mm (HxWxD), and what’s even more surprising is that it can still take full size ATX motherboards, as well as M-ATX and M-ITX boards. There’s also room in there for a few SSDs and HDDs, and we suspect even some watercooling. We have to say we’re a little excited about getting our hands on this case.
Technical Specification
| Dimensions | 359x245x394mm (HxWxD) |
| Motherboard Support | ATX, M-ATX, M-ITX |
| 5.25″ | 1 |
| 3.5″ | 1 Convertible between 2.5″ and 3.5″ |
| 2.5″ | 1 |
| Expansion bays | 7 |
| Air Cooling |
Front: 2x120mm (1 included) Base: 2x120mm Rear: 1x80mm |
| Water Cooling | 1x120mm, 1x240mm (not confirmed by Riotoro) |
| Max CPU Cooler Height | 135mm |
| Max GPU Length | 300mm |
| Max PSU Length | 175mm |
