Valkyrie V360 LCD CPU Liquid Cooler Review
Thermal Testing – Cinebench R24
OC3D CPU Cooler Stress Test
We want to push CPU coolers to their limit, and that requires a workload that will place maximum load on our i5-14600K CPU. Why didn’t we choose an i7 or an i9? The simple answer is that we want to test various CPU Cooler options. If we put the hottest CPU we could in our system, only the best of the best CPU coolers would even pass our testing procedures. Since not everyone uses such a power-hungry CPU, we decided to tone the wattage and thermal loads down by using an i5-14600K. Even so, this CPU consumes a lot of power and generates a lot of heat under all-core workloads.
For testing, we have used Cinebench R24. This is an all-core workload that places heavy strain on all available CPU cores. This load pushes CPU thermals higher than any other and does so consistently. We use Cinebench R24 for 30 minutes to see how hot our CPU gets over that time. If CPU temperatures rise to 100 degrees Celsius or over, that CPU cooler has failed our testing. This is part of the reason why there are more coolers on our higher fan RPM cooler charts. Some coolers will pass our thermal testing at higher fan RPMs but fail at lower fan RPMs.
1000 RPM Fan Test
In our demanding Cinebench thermal test, Valkyrie’s V360 LCD CPU cooler delivered the lowest thermals that we have seen on our test rig. These results could be seen at all RPM levels, cementing Valkyrie’s cooler as the best CPU cooler that we have tested to date.
1500 RPM Fan Speed Test
At 1500 RPM, Valkyrie’s new cooler is more than 1 degree cooler than our prior best. That difference matters in the world of high-end CPU coolers. A great result from a newcomer to the CPU cooling market.
Max RPM Fan Speed Test
Once again, the Valkyrie V360 LCD has given us strong results. Clearly, Valkyrie has done something good with this product.
