AMD Ryzen 7 9800X3D Review
Test Setup and Clock Speeds
Test Setup
CPU : AMD Ryzen 7 9800X3D
Motherboard : MSI MEG X870E Godlike
Case : BeQuiet! Light Base 900
PSU : MSI MEG Ai 1300p
GPU : Nvidia RTX 4090 FE
BeQuiet Light Loop 360
Memory Gskill Trident Z5 32GB
MSI 271QRX QD-OLED Monitor
Operating System : Windows 11 24H2
AGESA : ComboAm5PI 1.2.0.2b
With so much lighting available with the insanely impressive Godlike, it’s worth looking at it just on the desk. Sometimes you can’t tell where your money went, with the MSI X870E Godlike, it’s clear why it’s the flagship model in their range.
Plus live temperature monitoring is available on the built in screen. For those of us who fret about such things.
Speaking of gorgeous things, the MSI 271QRX OLED monitor is perfect for this. The AMD Ryzen 7 9800X3D produces incredible frame rates, and the OLED monitor produces incredible visuals. A match made in heaven.
Clock Speeds
The Ryzen 7 9800X3D can be pushed extremely hard if you have sufficient cooling. Even if you don’t want to manually fettle it the AMD software does a fine job in allocating work to each core and boosting them accordingly.
