ASUS ROG Maximus Z690 Formula Review
CPU Temperatures
There is no question that the latest Intel processors run hot. The 11th generation did and the 12th gen are no different. Sturdy cooling solutions, especially on the Core i9-12900K we’re using here, are a must. However, with some careful voltage management and the time to tune things properly, easy on the Formula, you can significantly reduce your thermal issues as you can see from our overclock temps.
