Published: July 29, 2009 |
Source:
Asus |
Author:
James Napier
ASUS Maximus II GENE mATX Motherboard
Â
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC. Each of the benchmarks below were run a total of five times with the highest and lowest scores being discarded and an average being calculated from the remaining three.
Â
Â
Â
Â
SuperPI is the benchmark of choice for many overclockers. It’s lightweight to download and can give a quick indication on how good a system is at number crunching. Once again, testing was performed a total of 5 times, with an average being calculated from the middle three results.
Â
Â
Â
Â
Â
PassMark is a popular benchmarking suite which test all aspect of PC hardware.The CPU test examines Mathematical operations, compression, encryption, SSE, 3DNow! instructions and more. Each CPU test was performed a total of 5 times, with an average being calculated from the middle three results.
Â
Â
Results Analysis
No surprises here really. The overclocked results of the E8400 at 4.3GHz completely stomp the stock results taken at 3.0GHz. If this shows us one thing, its that the combination of a cheap LGA775 CPU + a solid overclocking motherboard can really turn out some respectable results, especially in single-core benchmarks such as SuperPI that completely thrive on MHz performance.
