ASUS Maximus II GENE mATX Motherboard
It wasn’t so long ago that the mATX motherboard was deemed only acceptable for use inside HTPC setups or budget builds. Most came with shoddy low-end integrated graphics and nasty on-board sound chips and no enthusiast in their right minds would consider going anywhere near one. However, on the 27th February 2009 ASUS shocked us all. By splicing the features of their high-end Republic of Gamers Rampage II motherboard along the standard mATX form factor, the first ever performance i7 X58 mATX motherboard was born. Named the ASUS RoG Rampage II Gene, the board was received well by both enthusiasts and the press. Not only did it possess all the features of it’s larger ATX counterpart but it was also more affordable, better at overclocking and took the lead in many benchmarks.Intel® Socket 775 Core™2 Quad/Core™2 Extreme/Core™2 Duo/Pentium® dual-core/Celeron® dual-core / Celeron® Processors Support Intel® 45nm Multi-Core CPU
* Refer to www.asus.com for Intel CPU support list
Chipset
Intel® P45 /ICH10R
Front Side Bus
1600/1333/1066/800 MHz
Memory:
4 x DIMM, Max. 16 GB, DDR2 1300/1200/1066/800/667 Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*Refer to www.asus.com or this user manual for the Memory QVL(Qualified Vendors Lists).
Expansion Slots
2 x PCIe 2.0 x16 (single max @ x16,dual @ x8 speed)
1 x PCIe x1
1 x PCI 2.2
Multi-GPU Support
Support ATI CrossFireX™ Technology
Storage
Intel ICH10R controller
6 xSATA 3 Gb/s ports
Intel Matrix Storage Technology Support RAID 0,1,5,10
JMicron® JMB363 PATA and SATA controller
1 xUltraDMA 133/100/66/33 for up to 2 PATA devices
1 xExternal SATA 3.0 Gb/s port (SATA On-the-Go)
1 xSATA 3.0 Gb/s port
LAN
Gigabit LAN
Audio
SupremeFX X-Fi built-in
8 – Channel High Definition Audio CODEC
– EAX® Advanced™ HD 4.0
– X-Fi CMSS®-3D
– X-Fi Crystalizer™
– Creative ALchemy
IEEE 1394 2 x 1394a ports (1 port at back I/O, 1 port onboard)
USB 12 USB 2.0 ports (6 ports at back I/O, 6 ports onboard)
Overclocking Features
Keyboard-TweakIt
CPU Level Up
iROG
Extreme Tweaker
Loadline Calibration
Power Design:
– 8-phase CPU power
– 2-phase DRAM power
– 2-phase NB power
Intelligent overclocking tools:
– TurboV
– O.C Profile
– COP EX (Component Overheat Protection – EX)
– Voltiminder LED
– ASUS C.P.R.(CPU Parameter Recall)
Special Features
ASUS MyLogo 3
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
ASUS Q-Connector
External LCD Poster
MemOK!
One DIMM latch
Onboard Switches: Power / Reset / Memok / Clr CMOS (at rear)
ASUS EPU-6 Engine
ASUS Fan Xpert
