ASUS Rampage Extreme Motherboard
Â
Call of Duty 4 is quite possibly the ‘must have’ online multiplayer FPS of 2007/8. This is the fourth incarnation of Infinity Wards best-selling series and is set to become a stalwart of the FPS genre. The training sequence was run 5 times with the fps being recorded via Fraps and the average fps then deduced.
Â
Â
Â
Quake 4 is a game built on the Doom 3 engine. Benchmarking was performed using Quake4Bench and a custom timedemo recording along with 0xAA, 0xAF settings at a resolution of 1024×768. The benchmark was set to run a total of 5 times, with Quake4Bench automatically calculating an average result at the end of the run.
Â
Â
Â
Unreal Tournament 3 is the highly anticipated game from Epic Games and Midway. The game uses the latest Unreal engine, which combines fast gameplay along with high quality textures and lighting effects. All benchmarks were performed using UTbench with a fly-by of the DM-BioHazard map. As usual, all benchmarks were performed 5 times, with the highest and lowest results being removed and an average calculated from the remaining three.
Â
Â
Â
Results Observations
Â
The ASUS Rampage Formula doesn’t show the ASUS Blitz Formula SE a clear set of heels in the gaming performance testing either. Although it does slightly better in each benchmark, the difference between the two boards is negligable.
