Gigabyte Z490 Aorus Pro AX Preview
Up Close – Packaging and Contents
The Aorus Pro AX sticks to the now well established formula of Gigabyte Aorus products, with a large screaming eagle head and clear product image on the reverse with all the key features highlighted.
Inside the box we find a good selection of accessories as well as a case badge and the all important manual. It isn’t quite in the same comparmentalised system we saw on the Xtreme or even the Master, but it’s still better than just chucking them in the box.
SATA cables come in both right angle and straight style, so you have a choice depending upon how you prefer to set up your cable management.
The WiFi antenna that form part of the AX part of the Aorus model name are the now-standard triangular shape.
Whilst there are some RGB extension cables for helping you get your LED strips in exactly the right place so that you can show off your creativity in the best light without being compromised by short cables.
