Published: January 14, 2011 |
Source:
Gigabyte |
Author:
Tom Logan
Gigabyte P67A-UD7 Review
With the recently released P67 chipset from Intel supporting their latest LGA1155 socket, a replacement for the LGA1156, it’s not surprising to see many manufacturers releasing new boards to support this.
We’ve looked at a couple so far, the Maximus IV Extreme from ASUS, and the reference design board from Intel themselves.
However there has been a motherboard that for a long time we’ve been waiting to test. When we first got a glimpse of it a few months ago we were so stunned with its beauty that we had to show you a preview.
Now it’s finally here we can get cracking and see if the performance lives up to the looks.
Technical Specifications
There is some seriously high-end technology going on with the UD7. The Realtek ALC889 audio is the best on-board solution around. Twin, team-able, GigaLAN connections. The only x16/x16 Crossfire/SLI motherboard we’ve tested so far (both the other two run x8/x8). 4 SATA 6Gbp/s connectors and 2 6Gbp/s eSATA ones. 6x USB3.0 connectors and Dual-BIOS.
Normally we let the technical specifications table speak for itself, but having been heartily disappointed with the technology available on the ASUS offering it’s only right to highlight how much more up-to-date and acceptable the Gigabyte UD7 is.
| CPU |
- Support for Intel® Core™ i7 processors/Intel® Core™ i5 processors/ Intel® Core™ i3 processors/Intel® Pentium® processors/Intel® Celeron® processors in the LGA1155 package
- L3 cache varies with CPU
| Chipset |
- Intel® P67 Express Chipset
| Memory |
- 4 x 1.5V DDR3 DIMM sockets supporting up to 32 GB of system memory
- Dual channel memory architecture
- Support for DDR3 2133/1866/1600/1333/1066 MHz memory modules
- Support for non-ECC memory modules
- Support for Extreme Memory Profile (XMP) memory modules
| Audio |
- Realtek ALC889 codec
- High Definition Audio
- 2/4/5.1/7.1-channel
- Support for Dolby® Home Theater
- Support for S/PDIF Out
| LAN |
- 2 x Realtek RTL8111E chips (10/100/1000 Mbit)
- Support for Teaming
- Support for Smart Dual LAN
| Expansion Slots |
- 2 x PCI Express x16 slots, running at x16 (PCIEX16_1, PCIEX16_2)
* For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16_1 slot; if you are installing two PCI Express graphics cards, it is recommended that you install them in the PCIEX16_1 and PCIEX16_2 slots.
- 2 x PCI Express x16 slots, running at x8 (PCIEX8_1, PCIEX8_2)
* The PCIEX8_1 slot shares bandwidth with the PCIEX16_1 slot and the PCIEX8_2 slot with PCIEX16_2. The PCIEX16_1/PCIEX16_2 slot will operate at up to x8 mode when the PCIEX8_1/PCIEX8_2 is populated.
- 1 x PCI Express x1 slot
(All PCI Express slots conform to PCI Express 2.0 standard.)
- 2 x PCI slots
| Multi-Graphics Technology |
- Support for 2-Way/3-Way ATI CrossFireX™/NVIDIA SLI technology
| Storage Interface |
Chipset:
- 2 x SATA 6Gb/s connectors (SATA3_0, SATA3_1) supporting up to 2 SATA 6Gb/s devices
- 4 x SATA 3Gb/s connectors (SATA2_2~SATA2_5) supporting up to 4 SATA 3Gb/s devices
- Support for SATA RAID 0, RAID 1, RAID 5, and RAID 10
* When a RAID set is built across the SATA 6Gb/s and SATA 3Gb/s channels, the system performance of the RAID set may vary depending on the devices being connected.
2 x Marvell 88SE9128 chips:
- 2 x SATA 6Gb/s connectors (GSATA3_6, GSATA3_7) supporting up to 2 SATA 6Gb/s devices
- Support for SATA RAID 0 and RAID 1
- 2 x eSATA 6Gb/s connectors (eSATA/USB Combo) on the back panel supporting up to 2 SATA 6Gb/s devices
| USB |
Chipset:
- Up to 8 USB 2.0/1.1 ports (4 on the back panel, including 2 eSATA/USB Combo, 4 via the USB brackets connected to the internal USB headers)
2 x Renesas D720200 chips and 2 x VLI VL810 hubs:
- Up to 10 USB 3.0/2.0 ports (6 on the back panel, 4 via the USB brackets connected to the internal USB headers)
* The USB 2.0 signals of the 6 USB 3.0/2.0 ports on the back panel are from the Chipset.
| IEEE 1394 |
T.I. TSB43AB23 chip:
- Up to 3 IEEE 1394a ports (2 on the back panel, 1 via the IEEE 1394a bracket connected to the internal IEEE 1394a header)
| Internal I/O Connectors |
- 1 x 24-pin ATX main power connector
- 1 x 8-pin ATX 12V power connector
- 4 x SATA 6Gb/s connectors
- 1 x CPU fan header
- 3 x system fan headers
- 1 x power fan header
- 1 x Chipset fan header
- 1 x front panel header
- 1 x front panel audio header
- 1 x S/PDIF Out header
- 2 x USB 2.0/1.1 headers
- 2 x USB 3.0/2.0 headers
- 1 x IEEE 1394a header
- 1 x clearing CMOS button
- 1 x power button
- 1 x reset button
| Back Panel Connectors |
- 1 x PS/2 keyboard/mouse port
- 1 x optical S/PDIF Out connector
- 1 x coaxial S/PDIF Out connector
- 2 x IEEE 1394a ports
- 2 x USB 2.0/1.1 ports
- 6 x USB 3.0/2.0 ports
- 2 x eSATA/USB Combo connectors
- 2 x RJ-45 ports
- 6 x audio jacks (Center/Subwoofer Speaker Out/Rear Speaker Out/Side Speaker Out/Line In/Line Out/Microphone)
| I/O Controller |
- iTE IT8728 chip
| H/W Monitoring |
- System voltage detection
- CPU/System temperature detection
- CPU/System/Power fan speed detection
- CPU overheating warning
- CPU/System/Power fan fail warning
- CPU/System fan speed control
*Whether the CPU/system fan speed control function is supported will depend on the CPU/system cooler you install.
| BIOS |
- 2 x 32 Mbit flash
- Use of licensed AWARD BIOS
- Support for DualBIOS™
- PnP 1.0a, DMI 2.0, SM BIOS 2.4, ACPI 1.0b
| Unique Features |
- Support for @BIOS
- Support for Q-Flash
- Support for Xpress BIOS Rescue
- Support for Download Center
- Support for Xpress Install
- Support for Xpress Recovery2
- Support for EasyTune
* Available functions in EasyTune may differ by motherboard model.
- Support for Dynamic Energy Saver™ 2
- Support for Smart 6™
- Support for Auto Green
- Support for eXtreme Hard Drive (X.H.D)
- Support for ON/OFF Charge
- Support for Cloud OC
- Support for Q-Share
| Form Factor |
- ATX Form Factor; 30.5cm x 24.4cm
