ASUS ROG XG27ACS Monitor Review
OSD
OSD
If you like to control your monitor with the on-screen display (OSD), then the one on the ASUS ROG XG27ACS handles everything you could need to adjust. By including support not only for Nvidia G-SYNC but also AMD FreeSync and VESA AdaptiveSync, you can get a rock solid image whilst also using variable refresh rates.
If you play games with a heavy focus on skill cooldowns, the ability to have an on-screen Timer is one that could be a boon. Anything that helps you gain a fractional edge over your competitors could make the difference. Ignominious failure or chicken dinner? You decide.
