Corsair XENEON 32QHD165 Monitor Review
Up Close
As a 32″ monitor the Corsair Xeneon 32QHD165 is a beast of a display. Even compared to a 27″ model it’s amazing how much extra vision-filling loveliness those extra 5 inches will give you.
We will be covering the stand and stuff in more detail in a moment, but we know how much you appreciate a simple product overview shot, so here is the back of the Xeneon. A view we almost never see.
There is 100mm of height adjustment built in to the excellent stand, perfect if you want the ultimate flexibility for the comfort of your back.
So often we get monitors on stands which barely do anything, but as well as the height adjustment the Corsair Xeneon stand has -5° to 20° of tilt too. If you like your monitor low down but still facing you then you’re in luck. Equally if you have to wall mount it using the 100mm VESA mount then it still will face your.. erm.. face.
Although swivelling is the least used of the ergonomic adjustments it’s nice if you happen to have a corner desk. Anything that gives us some options of getting the monitor in exactly the right place is something we’ll applaud.
It’s worth noting the Xeneon stand has a large footprint. As well as the bit at the front to hold your Stream Deck there are two extra feet sticking out at the back. It certainly takes up a surprising amount of desk space even before we get to the 32″ of the panel itself.
