Corsair XENEON 32QHD165 Monitor Review
OSD
You can control the Xeneon using the Corsair iCUE software, which is certainly the simplest way to adjust things. However, Corsair also provide you with an excellent OSD should you prefer a more tactile adjustment experience or simply want to place a test image on the screen and adjust from that. Should you already have part of the Corsair ecosystem then you would be wisest to use iCUE as your one stop shop.
