Deus Ex: Mankind Divided PC Performance Review
To start off Deus Ex Mankind Divided is a demanding game, one that will bring many systems to their knees if they try to run it at max settings right out of the gate.Â
Mankind Divided is designed to run at 1080p 30FPS on the PS4 and 900p 30FPS on the Xbox One, which means that the combination of the higher resolutions and more demanding graphical options on the PC platform will require some top of the line hardware to run at a solid 60 frames per second, even at 1080p.Â
The joys of the PC platform are that we are given a lot of choices, whether we want to sacrifice graphical details and play the game at increased resolution and framerates or settle for the console-grade 30FPS with a lot of extra graphical yum-yum.Â
Even at 1080p, this game cannot be run at a solid 60FPS at maximum settings on our collection of GPUs, requiring gamers to make some visual sacrifices to achieve better in-game performance. Thankfully, the game does not have any major increases in graphical fidelity over high settings, so the highest settings are only really beneficial for taking static screenshots.Â
Control-wise there is very little to complain about, with the game coming with some great stock keyboard and mouse controls, full rebinding options, and controller support gamers will easily be able to find a control method that suits them. The game also has a huge list of HUD options which will help a lot of gamers to adjust the game to suit their preferences.Â
When it comes to graphical options Deus Ex: Mankind Divided offers gamers with almost every option that they could want, giving players plenty of options to gain performance or enhance the game’s graphical fidelity both inside and outside the game. The game also includes an FOV slider in-game, which sadly uses a percentage-based scale rather than a simple angle based scale, which most PC gamers will be more familiar with.Â
The only thing that I would like to see changed in the game’s graphical option is the potential addition of a resolution scale option, as I am confident that a lot of lower end gamers may want to lower their resolution slightly to achieve a more reliable framerate.Â
Hopefully the Deus Ex: Mankind Divided will be able to gain some extra performance when it’s DirectX 12 patch is added in the future, as I am sure that a lot of gamers would love to be able to turn their graphical settings that little bit higher.Â
All-in-all Deus Ex: Mankind Divided is a very demanding game, but the PC port is solid, we have experienced no issues during gameplay so far, even when using a broad range of hardware and such a variety of graphical settings. Hopefully Deus Ex: Mankind Divided’s performance will improve with new GPU drivers and with DirectX 12, but if your GPU is a recent model you should not have many issues achieving a playable framerate on PC.Â
Â
You can join the discussion on Deus Ex Mankind Divided’s PC performance on the OC3D Forums.Â
Â
Let’s have a look at Deus Ex: Mankind Divided’s PC performance.https://t.co/BNmu4HCBNj pic.twitter.com/ITEMgsRped
â OC3D (@OC3D) August 25, 2016
