MSI GTX 1080 Ti Lightning Review
Features
The first batch of feature highlights covers personalisation and enthusiast level features. It isn’t just the RGB lighting that you can tailor to your preferences, as the Lightning is able to have various colour flashes applied too. We’d probably stick with the all black look to help the RGB lighting pop, but of course the choice is yours.
The MSI GTX 1080 Ti Lightning isn’t only about letting you unleash your creativity in the looks department, you can also unleash your skill when it comes to overclocking. The Lightning comes with a raft of elements to allow you to maximise your overclock, whether it is a simple method of inputting beefy power, easy to access monitoring points, or high quality power phases, everything about the Lightning is designed to free you from the constraints of lesser hardware.
