Sapphire B850A Nitro+ WiFi7 Review
Temperatures
Temperatures
Our CPU temperature testing is a juxtaposition between best and worst case scenarios. We run a seriously heavyweight CPU cooler, which shows the best use case, and then torture the system for 30 minutes to get our peak reading. Otherwise known as the worst case scenario. Naturally in regular use you won’t see temperatures anything like this hot.
It’s also worth mentioning that we can’t find a sensor for VRMs on the Nitro+, so we can’t bring you those results at all.
