CM Storm Sentinel Z3RO-G Review
When we first looked at the CM Storm Sentinel Advance 18 months ago, it was as part of a look at the first range of gaming peripherals from the CM Storm branch of Cooler Master.
Today we’re taking a look at a slightly upgraded version, the CM Storm Sentinel Z3RO-G.
Slightly old school use of a 3 for an E aside, has this refresh kept it up at the top of the pack, or has it lost some of its charm? There is only one way to find out, so come with us now as we delve into the finer points of the Z3RO-G.
Technical Specifications
The specifications of the Z3RO-G is identical to the original Sentinel. Both have a twin 5600DPI sensor, the OLED screen and variable weighting. In fact it’s difficult to see where the mouse differs from its predecessor just by looking at the specs.
| Model Number | SGM-6001-GLLW1 |
| Available Color | Black and Grey |
| Material | Rubber Grip / ABS Plastic / Mesh Bezel / Metal Plate |
| Dimensions | (L) 135 X (W) 83.5 X (H) 40 mm / (L) 5.3 X (W) 3.3 X (H) 1.6 inch |
| Net Weight | 161.5 g / 0.356 lb |
| Sensor | 5600 DPI Storm TacticalTM Twin-laser Sensor |
| Form Factor | Right Hand Ergonomic |
| Button Assignment | 8 |
| DPI Display | OLED |
| Weight System | Yes, 4.5g X 5 pcs |
So if the pure specifications don’t give the game away, maybe a closer look will bring things to light.
