Corsair K55 RGB Pro XT Review
Software
The updated v4 of the Corsair iCUE software is as easy to use as the iCUE software always is. The refinements to the GUI, if anything, make it easier still to follow what you’re doing and make adjustments both simple and complex. If you’re new to iCUE the latest version also has plenty of tool tips and tutorials describing what you’ve just clicked on, so it’s very easy to get up to speed. Still the benchmark for software control in the peripheral world.
