Corsair K65 RGB Mini Keyboard Review
iCUE Software
The launch of the K65 RGB Mini also sees the newest iteration of the Corsair iCUE Software, version 4, launch. It’s very similar to the older versions, with everything easy to find and responsive. The K65 Mini has enough functions onboard – lighting, macro recording etc – that use of iCUE isn’t mandatory but it’s so easy to use that we’d recommend doing so if you can.
