Published: 12 March 2009 |
Source:
Crucial |
Author:
Rich Weatherstone
Crucial Ballistix Tracer DDR3 PC3-12800 6GB kit
Test Setup
For today’s testing we will be using the Gigabyte EX-58 UD5, a mid-range Core i7 motherboard from Gigabyte that will allow us to push the memory on test to its absolute limit. Here’s a breakdown of the rest of the components:
ProcessorIntel Core i7 920 ‘Nehalem’ @ 2.66Ghz
Motherboard
Gigabyte EX58-UD5
Memory
Mushkin 6GB (3x2GB) XP series DDR3 PC3-12800 1600MHz Kit 7-8-7-20
Patriot 6GB DDR3 PC3-12800 1600MHz Viper Series Low Latency Kit 8-8-8-24
Corsair CL8 1600MHz 8-8-8-24 3x2GB kit
Graphics Card
Nvidia 280GTX
Drivers
GeForce 180.60
PSU
Gigabyte Odin 1200w
Operating System
Windows Vista Ultimate 64bit SP1 + Updates
Setting the memory up presented no problems at all with our test rig. With just a few BIOS tweaks, we were up and running at the Ballistix stock settings of 8-8-8-24 @ 1600MHz. As you can see above the ‘Tracer’ effect of the ram is very domineering. The modules have four sets of LED’s, two ‘dormant’ sets at the base of the modules which light up the memory slot. These do not move and simply glow. Then the top of the module has two rows of eight “chasing” green LEDs atop the module, pulsating out from the centre in a random pattern based on memory utilisation. A custom-designed circuit relays bus activity to the LEDs, allowing them to accurately reflect usage of each memory module. Think 70’s Sci-Fi control panel and you are almost there. One can only assume that the different coloured heatsinks (Red, Blue and Green) would be matched by the same colour LED’s but don’t quote me on that. I personally like the effect the tracer LED’s give off but then I always was a sucker for gimmicks!
For testing the memory we used a number of synthetic benchmarks and games:
Synthetic Benchmarks
- Lavalys Everest 4.10
- SuperPI mod_1.5
- Sisoft Sandra 2009
3D Benchmarks
For the run of benchmarks, we will be comparing the 1600MHz 6GB Crucial Ballistix Tracer to the MuskinXP, Patriot Viper and Corsair Dominator kit.
Overclocking
Starting from scratch we disabled on the settings that may affect the overclocked settings such as Intel Speed Step as well as disabling the C-State settings which may also affect some of the results in the benchmark testing phase of the review. Here’s how the sticks look at stock speed:
Overclocking the Ballistix was very easy. First off I tried lowering the timings at the stock frequency and found 7-7-7 to be no trouble at all. I then tried CAS 6 latency but found this to be too much until I raised the voltage a little. With that tiny bump in voltage the sticks had no issues running at 6-6-6-20 @ 1600. Next up I attempted to overclock the frequency of the chips going straight for the throat @ 2000MHz. Sadly this ambitious attempt served nothing but to corrupt the Vista install. So one install later and a little more common sense I tried for 1800. They reached that level with no issues so I then raised the bar again to 1900, again, no issues apart from the fact I had to lower the latencies a notch. Next up was 1950 which was a no show, even with the latencies dropped again to CAS 10.
Settling for 1904MHz then with CAS 9 latencies is no poor show for the Ballistix and while it cannot possibly match the stonking 2100MHz the Mushkins managed in our last review, the Ballistix reached latencies the Mushkins could only dream of.
Returning the settings back to their stock values we then ran our suite of memory benchmarks to see how the modules compare. Let’s see how I got on…
