Crucial Ballistix Tracer DDR3 PC3-12800 6GB kit
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC. Each of the benchmarks below were run a total of five times with the highest and lowest scores being discarded and an average being calculated from the remaining three.
Surprisingly, the Crucial kit seemed to perform slightly worse than the other kits on test in the synthetic memory tests apart from SiSoft Sandra which placed the Crucial kit in top spot in the latency test which was surprising as it was running slightly higher latencies than the Mushkin kit. The Crucial kit did however make up ground in the 3 runs of SuperPI, narrowly losing out to the Mushkin kit but faster than both the Corsair and Patriot kits.
Let’s see how we got on with the run of 3D Benchmarks…
