DDR4 Overclocking with Thermaltake Toughram XG RGB
Cinebench R20
Continuing our rendering tests there are 44 points between the bottom and top result, a 0.007 (Hello Mr Bond) improvement. Very much within run tolerance rather than the kind of improvement that will leave you desperate to get into your BIOS and tinker. If you think 44 points is worth it then the fastest we ran, 4400 MHz, and the rated kit, 3600 MHz, is just 12 points.
