G,Skill Ripjaws X 2133MHz 8GB Kit Review
Test Setup
8GB G.Skill Ripjaws X 2133MHz
EVGA GTX570
Forceware 275.20
Gigabyte Z68X UD5 B3
Intel Core i5-2500K @ 4.4 GHz
Be Quiet Dark Power Pro
Windows 7 64 Bit SP1
Overclocking
Overclocking Memory is no longer as easy as it once was, thanks to the methodology employed by the LGA1155 platform. There isn’t a choice to go any higher than 2133MHz so we’re limited to timing changes.
The Ripjaws X are already at the 1.65v limit so we weren’t expecting much as we can’t pump some extra voltage through them for stability.
However, we did manage to slightly tighten things from 9-11-9-28-2N to 9-10-9-27-1N, and that will be the basis for our testing today.
