G,Skill Ripjaws X 2133MHz 8GB Kit Review
Sandra Memory Bandwidth
SiSoft’s Sandra uses a slightly different method to test than AIDA64, so it’s always good to get a breadth of results. Here the Ripjaws X perform right up there with the G.Skill Trident, and just below the Kingston Genesis.
Sandra Cache and Memory
The Cache and Memory bandwidth test combines the CPU and Memory to give a general indication of the bandwidth available to the system as a whole. Once again the Ripjaws X demonstrate that just because you need a lot of capacity, doesn’t mean you have to compromise on speed.
