Mushkin 6GB (3x2GB) XP series DDR3 PC3-12800 1600MHz Kit
Ubisoft has developed a new engine specifically for Far Cry 2, called Dunia, meaning “world”, “earth” or “living” in Parsi. The engine takes advantage of multi-core processors as well as multiple processors and supports DirectX 9 as well as DirectX 10. Running the Far Cry 2 benchmark tool the test was run 5 times with the highest and lowest scores being omitted and the average calculated from the remaining 3.
Results conclusions
The Mushkin kit increased scores and frames per second across the board out scoring both the Patriot and Corsair kits by a significant margin. 3DMark 05 showed the highest increase with over 1500 points difference. 3D05 is however becoming dated by todays standards and can throw up some curious results that differ greatly from run to run. There is no doubting though that over the whole 3D benchmarking process, the Mushkin is clearly the best kit for gaming.
Let’s head over to the conclusion…
