Mushkin XP2-6400 DDR2 2gb Kit
Specifications
The following specifications have been taken directly from Mushkin’s website:
“The eXtreme Performance 1GB XP2-6400 module (DDR2-800) offers enhanced second generation memory throughput and stability for the most demanding DDR2 computing platforms. A product of Mushkin’s exclusive EPIC (Enhanced Performance IC) selection process, the XP2-6400 is hand-tested to the highest quality and performance standards. The module is an unbuffered 240-Pin Double Data Rate x2 (DDR2) Synchronous DRAM Dual In-Line Memory Module (DIMM), organized as a dual-bank 128Mx64 high speed memory array using 64Mx8 chip density. This DIMM achieves high-speed data transfer rates of 800MHz at latencies of 4-4-3-10 (CAS-TRCD-TRP-TRAS). The XP2-6400 is enhanced by Mushkin’s Frostbyte heatspreader to ensure superior thermal performance and system reliability. With extreme performance and Mushkin’s renowned reliability, the XP2-6400 is the memory upgrade of choice for those DDR2 enthusiasts demanding more out of their high-performance system.”
Frequency: 800MHz
Latency: 4-4-3-10
Parity: Unbuffered
Voltage: 1-9V-2.1V
Pins: 240
Module Density: 128Mx64
Chip Desnsity: 64Mx8
Its good to see that Mushkin have managed to squeeze every ounce out of these chips in the latency department. Quite a lot of DDR2 chips are still rated in the 5-5-x-x range, but Mushkin have managed to reduce this to a respectable 4-4-3-10.
