Mushkin XP2-6400 DDR2 2gb Kit
With speeds reaching as high as DDR920 or latencies as low as 3-3-2-6 the Mushkin XP2-6400 is some seriously good DDR2 memory for overclockers and gamers wanting to venture into the 2gb market. It may not reach overclocks as high as its 1gb Kit counterpart, but this just the nature of the beast.
The stock timings of 4-4-3-10 are excellent for DDR2, beating out most manufacturers stock timings of 5-5-x-x, whilst also not requiring masses of voltage to get there.
Currently priced at $301 direct from Mushkin, this memory is by no means cheap. However, if you are looking for some great performing DDR2 that can do both tight timings and high frequencies, then this could well be the memory for you.
Pro’s
– Can do very tight timings at lower frequencies.
– Can overclock up to DDR920 with relaxed timings.
– Great looking black heatspreaders.
– Excellent stock timings
– Low voltage requirements
Con’s
– Price a tad high.
Thanks to Mushkin for providing this product for review.
Discuss this review in our forums..
