OCZ Blade DDR3 PC3-16000 6GB Kit
3DMark is a popular synthetic gaming benchmark used by many gamers and overclockers to gauge the performance of their PC’s. All 3DMark runs were performed a total of 5 times, with the highest and lowest results being removed and an average calculated from the remaining 3 results.
Ubisoft has developed a new engine specifically for Far Cry 2, called Dunia, meaning “world”, “earth” or “living” in Parsi. The engine takes advantage of multi-core processors as well as multiple processors and supports DirectX 9 as well as DirectX 10. Running the Far Cry 2 benchmark tool the test was run 5 times with the highest and lowest scores being omitted and the average calculated from the remaining 3.
Results conclusions
While reading the results above, consideration should be given to the fact the OCZ Blade kit was run with the CPU ever so slightly overclocked from a stock 2666MHz to 2717MHz. While this is hardly a dramatic increase, it is an increase nonetheless and should therefore be assessed while viewing the benchmarks results.
That said, the lead the OCZ kit has over the other kits on test is plain to see with the Blade ‘Dominating’ it’s nearest opposition throughout the testing.
Let’s head over to the conclusion…
