OC3D’s Best of Computex Awards 2024
Best Accessory
Best Accessory – Patriot’s iLuxe Cube
Sometimes we find products at Computex that we didn’t even know we wanted. The iLuxe Cube is essentially a phone backup device. It’s designed to connect to your phone charger and than connect to your phone at night. Overnight, it backs up your phone, protecting your data.
All you need to do is set up the device on Patriot’s app and it works. It’s a “set it and forget it” kind of device. If you break your phone, your data is on the Cube. It will be available with storage capacities of up to 1TB, and it can be used to back up multiple devices.
Depending on your use case, you can use this device to back up one phone or multiple phones. You can also choose how often you want your backups updated. If you lose or destroy your phone, this device will ensure that your important data remains available. All your family photos and videos will be stored on the iLuxe Cube.
The beauty of this device is its simplicity. Once you set up the Patriot app on your devices it will just work away in the background. Users can choose how their data is protected, be it behind a passcode, or another protection mechanism.
This is an awesome product. Backing up your data is important, as is making sure you don’t lose access to your family photos whenever you upgrade to a new phone. If you don’t have a phone backup option, this is a good one.
