BFG EX-1200 (1200W) Modular PSU
To provide our readers with the most accurate results, Overclock3D uses a professional grade SunMoon SM-268+ ATE load tester capable of placing a sustained load of 1690w across a total of six rails (including +5vsb and -12v) on the PSU. Unlike our previous resistor-based load tester, the SM-268+ gives us the ability to adjust amperage loads in increments as small as 0.01A while also measuring voltages and wattage readings on-screen.
During today’s tests, we will be placing the BFG EX Series 1200w under 25%, 50%, 75% and 100% load levels at both room temperature and inside a hot box regulated to a temperature of around 50°C. Additional cross load tests will also be performed under these conditions to simulate how the PSU would perform with a heavily uneven distribution of load. It should also be noted that the all +12v rails on the BFG EX will be combined during the testing, allowing us to make best use of the load testers configuration.
DC Watts
Exhaust
(Low)
271w
30.3°C
(Med)
538w
44.5°C
(High)
808w
56.5°C
(Full)
1065w
66.7°C
(x-load)
193w
45.5°C
(x-load)
890w
52.4°C
DC Watts
Exhaust
(Low)
271w
53.7°C
(Med)
538w
64.3°C
(High)
799w
71°C
(Full)
1065w
78°C
(x-load)
192w
67.6°C
(x-load)
889w
72°C
(Low)
(Med)
(High)
(Full) *
(x-load)
(x-load)
