BFG EX-1200 (1200W) Modular PSU
BFG Tech has taken a whole new approach to computer power supplies with the EX Series. Most power supplies are inefficient at lower loads, making it difficult to plan for future expansion while maintaining a green initiative. By using Frequency Conversion technology, the EX power supply can actually emulate virtually any size power supply and therefore be at least 80% efficient, even with loads as low as 10% of the unit’s maximum capability. EX power supplies have the lowest minimum load requirements and the best +5VSB efficiency on the market. BFG Tech uses all Japanese capacitors for longer life and gold-plated pins for improved conductivity.
• Includes six PCI Express® Connectors for Multi Graphics Card Support
• Features new 8-Pin PCI Express® Connectors
• Quad 12V Rails
• Lifetime Warranty* and 24/7 Tech Support
Specifications
• ATX12V 2.2/EPS12V 2.91
• Quad +12V Rails
• Silent 135mm Intake Fan
• Efficiency: > 80% Typical
• MTBF: > 100,000 Hours at 25°C, > 20,000 Hours at 40°C
• 1200W Continuous Rated at 40°
• PCI Express Ready
• Safety Approval: UL, CB, TUV, CE and FCC
• Dimensions: 15cm x 8.6cm x 16.5cm (5.9″ x 3.4″ x 6.5″)
