Enermax ECO80+ 350w ATX PSU
To provide our readers with the most accurate results, Overclock3D uses a professional grade SunMoon SM-268+ ATE load tester capable of placing a sustained load of 1690w across a total of six rails (including +5vsb and -12v) on the PSU. Unlike our previous resistor-based load tester, the SM-268+ gives us the ability to adjust amperage loads in increments as small as 0.01A while also measuring voltages and wattage readings on-screen.
During today’s tests, we will be placing the Enermax ECO80+ 350w under 25%, 50%, 75% and 100% load levels at both room temperature and inside a hot box regulated to a temperature of around 50°C. Additional ‘Cross Load’ and a ‘Max Load’ tests will also be performed under these conditions to simulate how the PSU reacts to heavily uneven loads as well as running above its specified output.
DC Watts
Exhaust
(Low)
87w
29.2°C
(Med)
175w
33.6°C
(High)
262w
40.4°C
(Full)
349w
43.1°C
(x-load)
102w
36.7°C
(x-load)
326w
44.6°C
(MAX)
449w
45.6°C
DC Watts
Exhaust
(Low)
87w
51.2°C
(Med)
175w
54.7°C
(High)
262w
57.8°C
(Full)
349w
62.4°C
(x-load)
102w
51.5°C
(x-load)
326w
55.5°C
(MAX)
448w
67.3°C
(Low)
(Med)
(High)
(Full)
(x-load)
(x-load)
