FSP Booster X3 300w 12v PSU
FSP have recognised the problem many people have been experiencing with SLI / Crossfire power issues and tackled it head-on. The Booster X3 is an excellent idea, and allows you to continue using you existing power supply without lagging behind (no pun) in the graphics card world.
With voltage fluctuation of only 0.4% when placed under 80% load, the Booster X3 provides more stable rails than a lot of high-end power supplies which is testament to FSP considering the size of the unit.
Let down by only its noise levels under load, and its slightly high price tag of £64 over at Microdirect, the Booster X3 is still a cheaper and easier alternative than to upgrading your existing power supply.
Komplett
It may also be worth noting that there is no technical reason why the Booster X3 couldn’t be used to power a Peltier, and would actually work out as a cheaper alternative than a dedicated Peltier PSU.
Pro’s
+ Stable power (only 0.4% fluctuation)
+ Good efficiency
+ Innovative solution for GPU power problem
+ Allows you to keep your existing PSU for longer
+ Could be used to power other devices such as a Peltier.
Con’s
– Noisy under full load
– PCI-E cables cannot be plugged in seperately.
– Slightly expensive
Recommended
Thanks to FSP Group for making this review possible.
Discuss this review in our forums.
