Silverstone Strider 850w ST85F PSU
Specifications
The following information has been taken directly from Silverstone’s Website:
| With continuous combined +12V output of 64A , the 850W addition to SilverStone’s Strider family has all that is capable of running a high-end system. Housed in the same environmentally friendly casing as the ST 75F , with 100% modular cable system and high quality cable bag, this power supply package is not only more advanced; it is also a cinch to manage. Cooled with a bigger and quieter 135mm fan, the ST 85F is an awesome all around power supply that delivers performance, optimal efficiency, and superior user comfort in its class! |
• Dual +12V with continuous 64A combined output
• 100% modular cables with cable bag
• Support dual PCI-E 8 pin connectors & quad PCI-E 6 pin connectors
• Silent running 135mm fan
• Support for ATX 12V 2.2 & EPS 12V
• Active PFC
• Efficiency greater than 80%
In addition to Silverstone making the decision to ‘downgrade’ the ST85F to two +12v rails instead of the original four, they have also incorporated the latest 8-Pin PCI-E connectors due to be used in upcoming graphics cards. The ST85F is also shown to be 2dBA quieter at idle than the previous ST75F model most likely owing to it’s slightly larger 135mm fan.
