Super Flower Leadex Platinum 1200W Review
12V Reading
The stability of the 12V rail is vital in ensuring the stability of your system and the lifespan of your components. You have to push the Leadex Platinum very hard indeed to get the 12V down to around the 12V mark, although the extra 10th of a volt in lower applications wont cause issues and there is very little difference between the PSU’s in this graph its mainly here for that time we do find a problem and it will be very easy to point it out.
