Gears of War 4 PC Performance Review
RX 480 VS GTX 1060 - Low, Medium, High and Ultra Settings
When placing the AMD RX 480 against the Nvidia GTX 1060 we can see that both GPUs do perform similarly, though Nvidia has the clear advantage in this game.
As a Nvidia branded title, which is currently available for free with GTX 1080 and GTX 1070 GPUs, it is no surprise that this new title has greater performance on Nvidia hardware, though it is worth noting that AMD's performance is not exactly stunted either.
At 1440p both GPU solutions are able to achieve playable levels of performance at 1440p, though gamers will need to lower a few settings, decrease their game resolution or use dynamic resolution scaling in order to achieve a constant 60+ FPS at 1440p.
13-10-2016, 16:23:05
AngryGoldfish
For every turd there is a chocolate bar.Quote
13-10-2016, 18:14:42
gijoe50000
Would be nice of they optimized the textures/game for certain amounts of vram. Having 4210MB makes no sense since the level down for 1080p is 2770MB. Everyone with a 4GB gpu will be missing out here.
There seems to be a huge gap between ultra and high..
It would make more sense to have the vram optimized as, say: 6GB for Ultra, 4GB for very high 3GB for high 2GB medium.
Does that make sense?Quote
13-10-2016, 18:47:06
NeverBackDown
Strange the only card using Async from Nvidia to lose performance was actually the 1080Quote
14-10-2016, 04:26:27
AlienALX
Might actually pull the trigger on this once I'm done with Mafia III (not even started yet lol).Quote
14-10-2016, 09:11:55
SPS
In UE4 you set a pre-defined texture streaming pool, this can either be set exactly or it can be set to be a percentage of VRAM. The streaming system well then only stream in the correct mips per texture where it is able to do so. If the texture pool is set to 20% of VRAM at low settings using 1080 (which has a fair bit of VRAM), it's possible that the VRAM report actually shows more VRAM being used than necessary. Once the pool is full it will only stream out textures when the memory being used is required for use by a texture coming into view. This helps prevent wasted time streaming out textures for the sake of it.
https://docs.unrealengine.com/latest...res/Streaming/Quote
