ADATA XPG Mars 980 Blade Gen5 M.2 Review
Temperature Testing
Temperature Testing
Low temperatures are the cornerstone of smooth, consistent transfer rates. You can buy drives either bare or with a heatsink. Most modern motherboards are designed in such a way a pre-installed heatsink might be problematic. At least this graph shows if you need to pay close attention to airflow across the lower half of your motherboard. We’re running the Mars 980 Blades just using the Godlike’s heatsink, rather than than the supplied one.
