Biwin NV7400 and X570 NVMe Drive Review
Temperature Testing
Temperature Testing
Low temperatures are the cornerstone of smooth, consistent transfer rates. You can buy drives either bare or with a heatsink. Most modern motherboards are designed in such a way a pre-installed heatsink might be problematic. At least this graph shows if you need to pay close attention to airflow across the lower half of your motherboard. It’s worth noting we use an insane torture test for our temperature graph. Real world use will see significantly lower temperatures on the X570 Pro and NV7400. Just glance at the Samsung 9100 and it’s 28°C reduction between torture and gaming for an idea of what to expect.
