All AMD & Asus Build and Performance Testing
Biwin Memory and Storage
Our memory today is courtesy of Biwin. New as a brand to these shores but by no means new in the market. You can only get them from Amazon at the minute, but with the Spring Deals going on there has never been a better time. We particularly like the striking purple colouring on the M.2s, whilst the memory supports all the major RGB controllers for full compatibility.
DW100 DDR5
Biwin have been in the market for far longer than you might think, albeit producing products for other brands. We don’t blame them for wondering if there isn’t a better way and if that is doing it themselves. It surely is. We all want the credit for our hard work after all. He says whilst typing at nearly midnight. The Biwin DW100 DDR5 has fantastic speeds and barely believable pricing for an RGB kit with these timings. Top stuff.
- Black Opal HX100 DDR5-6000 CL30 Memory – 2x16GB (32GB Total) – (Was £109.99 – Now £104.49)
- Black Opal DW100 RGB DDR5-6000 CL30 Memory – 2x16GB (32GB Total) – (Was £119.99 – Now £96.98)
X570 and NV7400 NVMe Drives
The Biwin range is especially good when it comes to dealing with a budget. For example, on the left the NV7400 will do 7.4GB/s for just a hair under £100. If you want to double that speed and really make use of the PCI Express 5.0 bandwidth, that’s double the price at £203.99. Pick your poison. For most, especially tight budgets, the NV is plenty. But if you want speed, the X570 Pro has your back.
