Aria Gladiator HD2-K Review
PC Mark Vantage
We’ve a couple of graphs today for PC Mark Vantage.
The first is the standard PC Mark result that you’re all used to, and as you can see the Gladiator HD2-K gives us some serious scores indeed across every test.
Regardless of the task you wish to perform the HD2-K has enough get up and go to deal with it.
Our test rig has a standard Samsung Spinpoint behind it, whereas this HD2-K is running with a SATA-III SSD.
In case there are any people left wondering if having even a small SSD as your OS drive can provide any benefits, here are the comparison scores between the Sabertooth on our bench rig with a similar overclock, and the Aria.co.uk Gladiator HD2-K with the OCZ SSD.
PC Mark 7
Further highlighting how much of an all-rounder the HD2-K is, PC Mark 7 really hasn’t got any weak links at all in its suite of tests. This really is a seriously power-packed system.
