AWD-IT ASUS A21 BTF System Review
ASUS BTF
ASUS BTF
The star of the show, and the thing we’re going to talk about most, is the ASUS TUF B760M-BTF D4 that gives this AWD-IT ASUS A21 BTF system its name. We don’t know what BTF stands for – although Behind The Front seems most obvious – but it’s all to do with the hidden connectors.
See. ALL the headers are around the other side. No need to carefully bend that giant 24 pin ATX cable around the motherboard to hide it. It’s already hidden. As are all the other headers.
Just a gap where the 8pin ATX CPU 12V power connector is normally found. The skin on our fingers thanks you.
All of which makes this photo of the back of the case even more revealing. Here it all is. Clearly this is not the type of motherboard that will fit in all cases, as most don’t have the cutouts. Similarly maybe not ever motherboard will fit in this case, because of differing placements. But this particular combination is made for each other. Perfect if you despise having any cables visible at all. It’s a bit of a marvel.
