PC DIY – Three Things To Do With A New System Build
GPU Tweak
For our Strix RTX 3080 you can utilise the ASUS GPU Tweak software which you can download from here. Once installed just click OC Mode and that’s it, you’re done.
Like our changes we made to the CPU in the UEFI we showed you on page two, this is also a one click way to give you more performance from your GPU, and the results on the next few pages utilise both the CPU and GPU changes. Remember this is four things you can change in a couple of minutes with zero knowledge.
