PCSpecialist Cruiser Havoc Black Friday System Review
There is a temptation to take the concept of a Black Friday deal and apply it solely to things that were already cheap. “Products from £49.99” or “Up to 70% off” sounds a lot better in advertising than just chopping 20% off everything. When PCSpecialist wanted to send us a system for review we feared it might belong to the RX 9060 + Intel Core i3 family. Instead the Cruiser Havoc is almost at the peak of what is possible.
When I Was a Young Warthog
Obviously we have to start with the case. We’ve not had this particular Corsair Warthog RS in for review yet. It’s safe to say a lot of things are good. We love the front intake, but also the ability to run fans in the side if you prefer. The military aesthetic is strong, especially in this Olive Green model. We like that all the panels are fixed with magnets. That might be a small thing, but for us, when our workflow involves taking things apart, photographing them, and putting them back together, not needing to also keep track of umpteen tiny screws is a boon. It also lets you clean the dust out easily, particularly with the mesh on the front.
All of that said, build flexibility and aesthetics etc, the lasting impression is weight. Built like a tank. If you had muscular shoulders you could beat a Rhino to death with it. Hell the delivery driver attempted to beat the shipment into a thousand pieces and the combo of stronk [sic] case and foam protection meant it looks like it had been delivered on a cloud by a concierge.
All The Flash Bits
About the only area where it feels like a corner has been cut is the motherboard. But, as we saw when we reviewed all the X870 ones, and have learnt through a lot of experience with this, the ASUS X870 TUF-Plus is actually all the motherboard you actually need. 10 Type-A USB, Three Type-C, 2.5G LAN and WiFi 7. Nuff said. On top of that PCSpecialist have done their usual trick of careful product selection. Corsair branding is strong, with 64GB @ 6000MHz of Vengeance DDR5. The 2TB M600 M.2 is more than fast enough for any realistic task, as well as being a nice size. Naturally memory is expensive these days so faster RAM, or a bigger capacity drive, would bust the budget.
It’s no surprise that the Ryzen 9 9950X3D is an incredible processor. The X3D models sell by the crate load. With 16 Cores and 32 Threads it doesn’t keep you waiting, regardless of the task you set it. Plus in gaming you get the benefits of the famous X3D V-Cache. Anywhere we can gain free FPS, even on a RTX 5080, we’ll take it. Speaking of which, the Palit RTX 5080 in our review sample might not win any flash and flair awards, especially when compared to some, but it’s quiet, cool, and does the job. Lastly, the Corsair Nautilus 360 keeps even this beast of a CPU cool when under heavy duress.
At a gnat’s nadger under the four grand mark, the PCSpecialist Cruiser Havoc is everything you would put into a dream build. The best AMD X3D CPU, plenty of RAM, and the gaming behemoth that is the RTX 5080 all wrapped up in a tank of a case win the Cruiser Havoc our OC3D Performance Award. At this Black Friday price, you’d be mad not to give it a long look.
Discuss the PCSpecialist Cruiser Havoc in our OC3D Forums.
