PCSpecialist Cruiser Havoc Black Friday System Review
Up Close
PCSpecialist Cruiser Havoc Review
Up Close
We often talk about the quality of PCSpecialist’s packaging. We will again in a moment. But with the Cruiser Havoc their efforts demonstrate the fruit they can bear. The delivery guy clearly fancied himself as a shot-putter. The outer box was in a terrible state. So much so that the box of accessories you always get with a system from the Wakefield people was very dented and mangled. Hence us including it here. This was inside the box, protected by foam.
Cruiser Havoc Accessories
The system itself? Flawless. Not a mark on it. Their efforts to protect your valuable purchase shine with deliver people like that.
First up the Corsair Warthog RS case itself. A weighty thing to be sure. It’s gigantic, all steel and weighs a ton. You could demolish a building with it. The Toyota Hilux of cases.
Cruiser Havoc Case
It would be impossible to have a military case without having additional ‘fighter jet’ accoutrements. At least you won’t accidentally reset your rig. Beneath the hinged, magnetically attached, front panel is an easy-to-remove dust trap. This might not be a case review, but the Corsair Warthog RS is very impressive.
Around the back you can get a feel for how wide this case is. Given it’s all-steel you definitely need to lift with your knees. Crikey.
A testament to the quality of the ASUS TUF range in recent years. Eight USB Type-A around the back, two at the front, along with two 40G Type-C at the back, and one 20G at the front. This is no longer a motherboard made as cheaply as possible but a genuine choice. The next one up in the ASUS range is the Strix-A, another £100 more expensive.
Cruiser Havoc IO
Around the back – thanks tool-less side panels – you can bask in the quality of the PCSpecialist cable management. Splendid stuff.
Cruiser Havoc Cable Management
The side you’ll see most often has diagonal bracing for the full military aesthetic. Obviously it means you can see less of the interior. But that’s okay. Not every case has to be a fishbowl. The first case I had with a window was the size of window you’d use to peer into the condemned. By that token the Corsair used in the Cruiser Havoc has a gigantic one.
With the side panel off, and the foam insert removed, we find.. more foam. As mentioned above, the courier took zero care of the box, but the system is still minty mint. This extra foam does it’s job, whilst also being obvious enough you don’t accidentally leave it in situ.
Cruiser Havoc Foam Protection
With all that out of the way we can enjoy the full majesty of the Cruiser Havoc. A big Corsair Nautilus 360 keeps the CPU cool. Chunky intake fans fill us with cool air, whilst the Palit RTX 5080 reminds us of the power at our disposal.
Certainly there is a lot of lighting available. The GPU and AIO are brighter than the sun, but the Corsair Vengeance RAM is also gorgeous. 64GB is the stuff of dreams for someone who has as much running as me and my 32GB. Capacity bests speed, although here the memory is still 6000 MHz. Impressive all around.
Cruiser Havoc Lighting
We know some people dislike colourful rigs, so here is the AIO set to white, just for you.
Cruiser Havoc White
There might be a Ryzen 9 9950X3D beneath that Corsair Nautilus pump, but we can’t help staring in awe at the RTX 5080.  What can we say, we love to game.
Von Blade
Von Blade
