Antec 1900 Gaming Case Review
Up Close:Â Exterior Overview and Roof
The Nineteen Hundred is available in Black with either Red (as seen here) or Green trim,  which should keep both AMD and Nvidia fan boys happy. Measuring 696mm (H) x 223.6mm (W) x 555mm (D) the Nineteen Hundred appears both tall, slim and narrow when sitting on your desk. In a major departure from recent Antec case designs, the lines of the Nineteen Hundred are largely clean, with only the accented mesh trim breaking things up.
Â
The left side of the case sports a large window 290x360mm, allowing a great view of the goodies inside. The window is thoughtfully positioned towards the rear of the side panel so as to mask off the drive bay area.  On either side of the base of the case there are two doors which, being hinged at the bottom open to reveal additional storage as well as a second PSU mount.
Â
The roof of the case is largely plain with only an elongated oval mesh area breaking up the lines. The mesh area seems small by comparison to the rest of the case, around 240mm in fact, our first hint that hopes of native 360mm rads in the roof might not be about to be dashed.
