Peak Airflow – NZXT’s H9 Flow Dual-Chamber PC case appears on Amazon
Peak Airflow - NZXT's H9 Flow Dual-Chamber PC case appears on Amazon
NZXT’s upcoming H9 Flow chassis has appeared on Amazon US
A new case from NZXT has appeared on Amazon’s US website, a dual-chambered chassis that is designed to support up to three 360mm radiators and provide inside levels of airflow to users. Meet the NZXT H9, what could be the ultimate airflow PC case.
With space for up to 10 120mm fans, NZXT’s new H9 Flow chassis is designed to deliver huge amounts of airflow to components while also giving users the ability to view their hardware though the case’s front and side panel windows. PC builders can have a huge amount of airflow within their systems while also having an unobstructed view of their hardware. If this case works as well as intended, this could be the ultimate blend of airflow and visual appeal.
As mentioned before, NZXT’s H9 chassis is a dual-chambered PC case, with the case’s PSU, HDD mounts, and 2.5-inch drive bays being hidden behind the H9’s motherboard tray. This design is what allows the H9 Flow to receive airflow from so many areas, while also allowing users of this case to have a large number of storage drives and other add-ons.
At this time, the pricing and release date of NZXT’s upcoming H9 Flow chassis are unknown. We only know about this new PC case because of its early Amazon listing, and we expect NZXT to remove their retail listing once they find out it has gone live.
Based on this case’s Amazon page, the H9 will ship with four 120mm fans out of the box, which means that users will need to purchase six additional 120mm fans to fill up all of this case’s fan mounts.
You can join the discussion on NZXT’s H9 Flow chassis on the OC3D Forums.
