Intel “Ice Lake” CPU reportedly offers 40% IPC uplift in benchmark
IPC as a catch-all term doesn’t apply to all benchmarks, so single workloads should not be seen as representative of all scenarios. Some programs will benefit significantly from specific architectural enhancement, whereas some applications may not be impacted at all.
Recently, benchmarking data from a Chinese forum has been making the rounds, highlighting that Ice Lake offers a 40% IPC boost over Skylake in a version of CPU-Z in single-threaded workloads.
For starters, CPU-Z isn’t a great benchmark to using here, as it is worth remembering that the tool’s benchmark needed to be redesigned to accommodate AMD’s Ryzen processors (more info on this is available here), which in the tool’s original benchmark offered a 30% IPC advantage over Intel, something which was not replicable outside of CPU-Z. Similar issues could be happening with Ice Lake, or this data could be entirely false.
Another factor that’s worth noting is that these benchmark results contain some strange data, including benchmark results from unreleased Ryzen 3rd Generation processors and benchmark results from processors which are operating well in excess of what should be considered normal clock speeds. A 5.4GHz i9-9900K, a 5.1GHz Xeon W-3175X and a 5.4GHz i7-7740X? Suspicious.
Even if Ice Lake offers a 40% IPC here, it is worth remembering that IPC in a specific application is not indicative of performance in other scenarios. See the chart below and how Intel’s Ice Lake/Sunny Cove performance advantage varies across a wide range of tests. 18% was found to be an average value for IPC improvement, but as you can see outlier results have performance gains in the single-digit percentages while others can see performance benefits of greater than 30%.
As you can see in the slide below, which comes from Intel, the company’s Sunny Cove/Ice Lake processors can offer between 0% and 40% performance gains over Skylake. This is why average values matter, but when it comes to IPC gains, they should always be considered as application specific, though average changes are useful for explaining generational performance trends.
In our eyes, this data is highly suspicious, uses a benchmark that has been known to react strangely to new CPU architectures and if true presents data that is not representative of Intel’s IPC claims for Ice Lake.
Don’t look at this result and think that Ice Lake is going to be amazing. Temper your expectations, if Intel advertises an 18% IPC boost, don’t believe a random forum post that promises a 40% uplift. This data is more than suspicious enough to dismiss, but, as usual, this info has been spread through enough tech sites that we feel the need to bring some common sense to this discussion.
You can join the discussion on Ice Lake’s reported 40% IPC uplift on the OC3D Forums.
