MSI’s GTX 1080 Ti Lightning Z has been pictured and specced
MSI's GTX 1080 Ti Lightning has been pictured and specced
MSI’s new GTX 1080 Ti Lightning Z has now been pictured by attendees of Computex 2017, revealing not only several aspects of the GPU’s design but also the GPU’s specifications.
This new GPU will operate with three different clock speed modes, a silent mode which runs at Nvidia reference GTX 1080 Ti clock speeds, Gaming mode which runs at 1582MHz/1695MHz base/boost clock speeds and Lightning mode which runs at 1607MHz and 1721MHz.  All modes except for silent runs the GPU’s GDDR5X memory at 11120MHz
Below is a table that compared the specification of the GTX 1080 Ti Lightning Z and MSI’s existing GTX 1080 Ti Gaming X.
  GTX 1080 Ti Founders Edition MSI GTX 1080 Ti Gaming X MSI GTX 1080 Ti Lightning
GPU Architecture Pascal Pascal Pascal
Process node 16nm 16nm 16nm
SM Units 56 56 56
Cores per SM 64 64 64
CUDA Core Count 3584 3584 3584
ROPs 88 88 88
VRAM Type GDDR5X GDDR5X  GDDR5X
Memory Clock 11008MHz 11100MHz 11120MHz
VRAM Cappacity 11GB 11GB  11GB
Memory Bus Size 352-bit 352-bit  352-bit
Memory Bandwidth 484 GB/s 484 GB/s  48 GB/s
Base clock speed 1480MHz 1569MHz  1607MHz
Boost clock speed 1582MHz 1683MHz  1721MHz
Power Connection
1x 8-pin 1x 6-pin
2x 8-pin  3x 8-pin
PCI Express  PCIe 3.0 PCIe 3.0  PCIe 3.0
This new overclocking GTX 1080 Ti variant will come with 3 -8-pin power connections, which will be sure to allow this card to be supplied more than enough power under LN2 overclocking loads.
The MSI GTX 1080 Ti Lightning Z is expected to support RGB LED lighting, though at this time this has not been confirmed.
(Image from Tweaktown)
On the rear I/O this GPU will support dual HDMI 2.0b ports, dual DisplayPort 1.4 ports and a single DVI-D port, with this GPU sporting an extra tall PCB design and a 3-slot cooler.
You can join the discussion on MSI’s GTX 1080 Ti Lighting Z GPU on the OC3D Forums.
