G.Skill launches Ultra-low latency Trident Z5 Royal Neo series DDR5 kits for AMD Ryzen systems
G.Skill delivers ultra-low latency DDR5-6000 memory in time for AMD’s Ryzen 9000 series launch
Ahead of the launch of AMD’s delayed Ryzen 9000 series CPUs, G.Skill has launched a new series of ultra-low latency DDR5 memory kits. These kits are new additions to the Trident Z5 Royal Neo series. These new kits boast CL28 timings, DDR5-6000 speeds, and AMD EXPO support.
Specifically, G.Skill are launching new low latency DDR5-6000 memory kits with 32GB (2x16GB), 48GB (2x24GB), 64GB (2x32GB), and 96GB (2x48GB) kit capacities. The 32GB and 64GB kits will feature CL28-36-36-96 timings. The 48GB and 96GB kits will feature CL28-38-38-96 timings.
Low latency memory can have a huge impact on the performance of some workloads. It can be a critical factor when trying to squeeze more performance our of your systems. Lower memory timings result in a lessened delay in actions. With low latency memory, a PC is more responsive, as your CPU can receive data with less delay and start working on that data faster. Less time waiting means more time working, which is why lowered memory latencies can result in notable performance gains. Even so, optimal system performance comes when users find an optimal balance between memory speeds and memory latencies.
When compared to standard DDR5-4800 CL40 kits, these new DDR5-6000 CL28 memory kits from G.Skill are incredibly fast. This is both in latency and frequency terms. PC builders using DDR5 shouldn’t buy baseline DDR5 memory, as doing so leaves a lot of performance on the table.
With these new low latency DDR5 modules, G.Skill hopes to deliver an optimal balance between speed, latency, and memory capacity for Ryzen CPU users. These new modules will be available to purchase in August, just in time for AMD’s Ryzen 9000 CPU launch.
You can join the discussion on G.Skill’s new Trident Z5 Royal Neo DDR5-6000 CL28 DDR5 memory kits on the OC3D Forums.
